cstockdale
supafly killa homey
can the AP 2496 simultaneously route the input signal (say coming from an external mixing board) back out of the outputs and into a software application at the same time?
i.e. I use a Behringer 602A mixer connected via the aux outs to the ins of the 2496, and the outs of the soundcard go to a stereo pair in my mixer to monitor what I have recorded already. I don't use "input monitoring" in Sonar, because I get a slight latency problem, not much, but enough to provide a "chorus" feel due to a very short delay, and it throws my timing off. The way I am configured, I get to monitor my input direct from the board , and hear stuff out of Sonar at the same time. However, the Berhinger mixer only has one aux out, and it is Mono. I therefore am effectively giving myself only one input to Sonar.
I can't use the main outs or control room outs from teh mixer into the 2496 because everything that comes into the board goes out the main outs: I would end up looping what I have already recorded back in with what I am trying to currently record.
I have one other option to get my two ins to the 2496.
I can use the Main Outs IF and only IF I use the Tape Ins as my monitoring source from teh 2496 outs because I can select whether or not the Tape In goes to teh main mix OR to the control room mix. There is a catch here: if I use this routing, when I depress the 2TK-->Control Room button, it cuts out the mains, so I can't hear what I am currently recording anymore, and I have to use the "input monitoring" option in SONAR to hear what I am putting in. As I have already outlined above, this is not a desirable way of recording due to a slight processing lag (ie I have to wait a few ms for the input signal to go through the card, get converted, run into SONAR, run back to the card, get converted again for me to hear).
I haven't tried this yet, but in the patchbay router section of the 2496 windows that pop up, I can select H/W In 1/2 in teh H/W Out 1/2 section, which would send my input signal straight back out to the mixer.....
The short bit here: can I send an input signal to the 2496 card that will get sent straight back out to the Mixer (so that I can monitor what I am recording without having to send it all the way to SONAR and back) AND send it on to Sonar at the same time? This way I could connect my Eurorack 602A mixer to the 2496 via the main outs, get my two inputs, and hear what I am recording via the Tape Ins on the mixer and monitor what I am recording at the same time?
