C
cyclejim
I downloaded the manual for the 24/96 because I am considering buying one. I have a question on the inputs for recording.
According to the manual, you can connect a LINE LEVEL signal from your instrument, mixer, or pre-amp. The actual connectors on the card are RCA phono type.
Don't most mixers, pre-amps tend to use XLR or 1/4 outputs? If this is the case, is it a common need to get a RCA phono to 1/4 adapter (or XLR if that animal exists) when using the 24/96?
Also, the system requirements do not show Windows XP as a supported OS. Anyone using this under XP?
Thanks in advance
Jim
Thanks in advance
Jim
