J
jackstpaulUHS
I'm not clear on the issue of audio interfaces functioning as soundcard.
What I heard, from a GC sales guy, is that an interface used with PT, Cubase, etc. will function as the sound card when it's in use. I've read some brief comments on-line, but to be sure I understand it:
I'm about to buy the Dell laptop below, and I’ve heard that laptops are limited re: soundcards because you can't replace the one that comes with it (true?).
But if some sort of interface like m-audio functions as my sound card, then the limit of being stuck with the laptop’s built-in sound card is moot, right?
I’ve been using CoolEdit Pro 2.1a, so I don’t have experience with using an interface.
I’m not decided on the software, but probably Cubase. I can decide on the interface later, too.
Thanks.
Dell Inspiron 1525-122B $595
Vista Home Premium SP1; 2.0GHz Intel Core 2 Duo T5750; 3072MB DDR2 SDRAM 667MHz , chipset --Intel GM965 250GB Western Digital 5,400rpm. DATA: 4 USB 2.0, mini FireWire, multiformat memory card reader EXPANSION: ExpressCard/54 NETWORK Modem, Ethernet, 802.11 a/b/g Wi-Fi 128MB Mobile Intel 965GM Express;
Thanks.
