6
66BobbyQ
This may not be an issue at all. It may just be my failure to understand.
First my equipment and signal chain:
Sterling condenser mic --> Mackie Profx8 mixer ch 2 --> Behringer Compser Pro-XL ('insert' mixer ch2) --> Mackie mixer main outs --> UR44 lines 5 & 6.
I have connections for the UR44 configured in Cubase 10.5 as 3 stereo inputs. I am also using control room so I have no outputs connected. I am monitoring through main mix (mix1/JBL monitors) & headphones(mix2/RevoNexteasrbuds).
Should also mention, that I have direct monitoring off with loopback enabled in Cubase.
I created a audio track for the mic using stereo channel 3 as an input and mix1 as the stereo out. When I monitor this track I hear a slight doubling of the audio. It doesn't matter if it is mix1 or mix2 or, JBLs or earbuds. If I turn on 'Direct Monitoring' in the Cubase setup it goes away. I already have stereo input 1 on the interface muted in Cubase to avoid doubling on that channel since I have loopback enabled. Anything I record on said track does not have the doubling it is only in the monitoring.
It seems to me (and I can be wrong) that I had resolved this issue before. I don't care about latency because its minimal but the doubling I hear sounds like reverb. This really throws me off because I can't get a real idea as to how things really sound cause everything seems to be washed in an annoying crappy reverb.
Is there a simple fix or am I out of my cotton picking mind?
I hope I explained this well enough to be understood. Please let me know if further info is needed.
