Audacity question
  • Thread starter Thread starter Dimensions
D
Dimensions
All I want to do is make a mix with labelled tracks, so that the listener can skip from track to track (but with no gap between tracks)
I've labelled all the tracks on Audacity at the right points, but when I 'export multiple' it splits them up into seperate tracks, and when I 'export audio' it exports as a mix that doesn't let me skip between tracks.
Any ideas peeps?
Cheers
Well, you're either exporting ONE mix or several. Whatever the gap. If you want to skip from track to track, there must be tracks to skip to (and from).
The system seems to be working as it should. If it's a matter of making sure they play back in a particular order, add "01" "02" (etc.) to the beginning of the name in the editor.
You could theoretically export bin/cue or DDP, but the average listener isn't going to have the software to play that back...
