promesis
Black Knights of the 4H.
what if I need to attenuate the signal out of the external pres .. as it is now:
Mics going straight into the Mackie Board, a couple of mics send pretty hot signals even with their -10 pad engaged and the Mackie input channel trim fully ccw, I still need to drop the faders a few dB to keep from clipping the recorder
The RNPs do not have an output level .. I am thinking about getting a couple of Mecenary Audio's racked RNPs/RNCs
http://www.mercenary.com/2rnhoinfulof.html
Given this scenerio, with the RNC connected to the inserts of its companion RNP, would it be advisable to maybe use the Gain settings of the RNC to attenuate the levels going into the recorder? Or is there a different and better way of attaining this, almost assured necessary, level attenuation since I would rather by-pass the board all together when the pres are purchased?
Thanks for your time.
The RNPs do not have an output level .. I am thinking about getting a couple of Mecenary Audio's racked RNPs/RNCs http://www.mercenary.com/2rnhoinfulof.html
The issue comes up again with a True Precesion 8 pre with dynamics on kick and snare- min 15 dB gain at the pre, and it needs a 15 dB pad on the output. Silly really.
