mshilarious
Banned
Do the UAD emulations sound exactly like the hardware? The debate continues, but not here!
One significant difference I have noted in the past was that no UAD plug I have tested (I have most of the pre-UAD-2 release plugs) generates any even-order harmonic distortion at all. Literally none. 0%.
Since that is the desired type of harmonic distortion, and second-order distortion is often the dominant type of distortion in a circuit, that's a serious problem if one is trying to emulate an analog circuit. It baffles me why UA didn't model that behavior.
Well, I can't do emulations, but I can help fix this problem. Even-order distortion is an asymmetrical distortion of a waveform; that is, it occurs to a different degree to the top and bottom of the wave. Whereas odd-order is a symmetrical distortion; that is the behavior that all UAD compressors exhibit (since they are compressing symmetrically).
So all we need to do is feed the plug a waveform with DC offset. The UAD plug will compress one half of the wave more than the other half due to the offset. Et voila, even-order harmonic distortion!
Note that this only works if the compression algorithm is not preceded by a high-pass filter, because the high-pass filter will remove the DC offset and spoil our plans. Fortunately, most of the UAD compressors don't seem to have that feature (which is odd if you are emulating an analog circuit, because most analog inputs won't pass a DC offset).
So I humbly present Simon, the ugly little runt brother to Nigel:
Simon
Simon is a .dll file that you will need to save to your VST plugs folder. It's very simple: one knob is DC offset from 0 to 1, the other knob is gain up to 100 (+40dB).
Place Simon in front of the UAD plug that you want to generate even-order distortion. I have verified that it works with the following plugs:
- Nigel (compressor must be active, recommended ratio of 4 or greater)
- LA2A
- LA3A
- 1176LN
It does NOT work with the Fairchild.
Anyway, by twiddling with the knobs in Simon and Nigel, you can generate a MUCH larger variety of overtones than Nigel itself can manage; forgive me for saying that I think it breathes new life into a plug that UA has abandoned. I recommend avoiding the Bent knob if you want clean and phat, it just adds high-order distortion. Select the Supa Clean amp model, keep Color and Bent low, set input Lows very low and make up the lows with the output Low knob, and you'll have a clean sound with very high second order distortion and almost no higher-order distortion.
Enjoy, and let me know about the UAD compressors I don't have, and any glitches you find!
Simon
- LA2A
- LA3A
- 1176LN
