N
nagol5178
I realize there are a lot of topics on this. But there is something confusing me about this situation. If my outboard compressor only has TRS Balanced and XLR balanced inputs and outputs, then how do I connect it to my M-Audio fast track pro?
I have read on here that you would get a Y cable, which is a TRS on one side that goes into insert 1, and then plug the TS unbalanced cables into the compressor. But since the compressor is balanced, would I still be able to do this?
This is my first time installing outboard gear. As I am building my first studio. Is there another method I should use or does the Y cable into insert one still apply even if these are balanced inputs and outputs and the Y cables are not on one side?
Thanks in advance for your help.
