arcadeko
Illuminatius Overlordious
SOLD
$275 OBO - (they sell new for $275 - $350 without stands and cables.)
2 Kustom KSC 10" Speakers
1 Kustom KPM 4080 PA Head
2 On Stage Stands Extreme SS7755
2 Unbalanced Speaker Cables
Note: They are in perfect condition except for one speaker has a crack in the recessed plastic mounting plate that holds the cable jacks. The crack has been repaired and the inputs work fine.
Kustom KPM 4080
RMS Wattage: 80 Watts
Channels: 4
Instrument-Ready Preamp Input: -
Microphone Input: 4 Balanced XLR
Phantom Mic Power: Yes
Line Level Input: 4
EQ: Per Channel
Master EQ: 3-Band
Effects: Analog Spring Reverb
Record Out: Left & Right Jacks
C D/Tape/iPod Input: w/Volume Control
Dimensions: 4.8H x 18.3W x 9.8D
Dimensions (mm): 121H x 464W x 248D
Weight: 22 lbs/ 10 kg
Kustom KSC 10:
75 Watt RMS/150 Peak Power Handling
10" Speakers
High Frequency Driver
75 Hz - 18 kHz Frequency Response
93 dB Sensitivity
8 Ohm Impedance
Dimensions - 19"H x 12.5"W x 9.5"D
Dimensions - 483H x 318W x 241D
Weight - 17.7 lbs/ 8 kg.
Info: Kustom KPA804 Complete PA System
KPA80 Kustom 80W PA System
Kustom KPM 4080
Channels: 4
Line Level Input: 4
EQ: Per Channel
Master EQ: 3-Band
Kustom KSC 10:
10" Speakers
93 dB Sensitivity
8 Ohm Impedance
