AT4047 Users
  • Thread starter Thread starter Minker
M
Minker
Just curious--Do you use the high pass filter when recording vocals?
How bout when recording finger picked acoustic guitars?
The high-pass filter is at 80Hz. I recommend you engage it all the time - except perhaps if you're recording the low end of a piano. What a high-pass filter does is allow all the frequencies about the cut-off mark to "pass" through. In the case of the 4047 all the frequencies below 80Hz are not allowed to pass through. What the high-pass filter does in practice is not allowing the kinds of low frequencies that would cause rumble or low end ambient noise to come through the mic. It's actually a good idea to use a high-pass filter somewhere around 80-100Hz on everything except bass, kick and low piano or synth notes. Other than that, there's no frequencies below that point that help define many instruments such as voice, acoustic guitar, amps, drum OH's, most percussion, brass, strings [ except for bass and maybe cello ] And leaving in those frequencies can contribute greatly to having a muddy mix that's not defined. There's some exceptions: If you have a Marshall stack you might not want to use it if it turns out that leaving some of the lower frequencies will give it more body. And you can also decide that in the mix.
You'll also find that using a high-pass filter will give you more headroom for what you're recording because low-frequency rumbling that can take up headroom won't ever even make it past the mic.
Thanks again Dot. Sorry to be redundant, you explained that once before and I understand and highly respect your opinion! In fact I was hoping you wouldn't see this question for fear of looking like a knuckle head.(You caught me!) Just wondering if others felt any different. In theory what your saying is dead on, but I wondered if anyone felt the filter may reduce a sense of "fullness". I know you know all about this mic, but with you vast pallet of choices, do you actually use it much on vocals?
I would take care to sculpt the low end on bass, kicks, some guitars, but if it doesn't need it I leave it alone. On vocals, if there's no problem I'd err on the side of weight.
Even with the 4047 being a little on the warm side, 500-900 often seems to come up a bit hot on male vocals.
Dan, I raised this follow-up question that last time you posted this info., so let me see if I can reach you there this time. I've been looking at LDCs and notice that the low-cut choice is usually either 80Hz or 100Hz. So...
For recording solo acoustic guitar, steel and nylon, which would normally (all things equal) be the better cut-off freq
--80Hz or 100Hz? Or would the difference be unnoticable on lower-end equipment?
Thanks to you (or anyone here) for any advice,
J.
