AT 4060 Vs...
  • Thread starter Thread starter BEK$
B
BEK$
Wondering if I can get any view from any of you who have an AT 4060, likes? dislikes ? Your signal chain ? Do you have any Neumanns etc ? Comparative wise...
I was going to buy a new Large Diaphram Condensor Mic for Vocals and was looking at the Nuemann U87 and the Lawson L47 if I have my models correct.
A rep at Proaudiodesign.com recommended the AT4060 because the specs on it were as good and in fact better than both of the more expensive mics.
I love my AT4060 and I price Matched it for about $900 at Guitar Center.
A U87 is over $2K
Here's all the individual Specs.
Hope this helps.
Nuemann U87
Acoustical operating principle Pressure gradient transducer
Directional pattern Omnidirectional, cardioid, figure-8 plus
Frequency range 20 Hz ... 20 kHz
Sensitivity at 1 kHz into 1 kohm 20/28/22 mV/Pa*
Rated impedance 200 ohms
Rated load impedance 1000 ohms
Equivalent SPL CCIR 468-3 26/23/25 dB*
Equivalent SPL DIN/IEC 651 15/12/14 dB-A*
S/N ratio CCIR 468-3 68/71/69 dB*
S/N ratio DIN/IEC 651 79/82/80 dB*
Maximum SPL for THD 0.5% 117 dB (cardioid)
Maximum SPL for THD 0.5% with preattenuation 127 dB
Maximum output voltage 390 mV
Dynamic range of the microphone amplifier cardioid DIN/IEC 651 105 dB
Supply voltage 48 V ± 4 V
Lawson L47
Frequency Range 20 to 20 kHz
Polar Patterns Cardioid, omni-directional, figure 8, and infinite intermediate patterns; also cardioid-only position
Sensitivity at 1 kHz 11.4 mV @ 1 Pascal (94 dB SPL)
18.2 mV (cardioid only position)
Max SPL (1 kHz 3%) 128 dB
(138 dB SPL with -10 dB pad)
Equivalent Noise Level 22 dBA multi-pattern
19 dBA cardioid-only mode
Rated Impedance 150 ohms
Tube 6N1P dual triode
Connector 7-pin gold-plated XLR
Pad -10 dB
Dimensions Mic: 9.75"L, 2.375"D
Supply: 8"L X 4.375"W X 2.625"H
Shipping Weight 14 lbs.
Power Supply 100/120/200/220/240 VAC factory set
Audio Technica 4060
POLAR PATTERN Cardioid
FREQUENCY RESPONSE 20-20,000 Hz
OPEN CIRCUIT SENSITIVITY -34 dB (19.9 mV) re 1V at 1 Pa
IMPEDANCE 200 ohms
MAXIMUM INPUT SOUND LEVEL 150 dB SPL, 1 kHz at 1% T.H.D.;
149 dB SPL, 1 kHz at 0.5% T.H.D.
NOISE 19 dB SPL
DYNAMIC RANGE (typical) 131 dB, 1 kHz at Max SPL
SIGNAL-TO-NOISE RATIO 75 dB, 1 kHz at 1 Pa
POWER REQUIREMENTS AT8560 power supply (120V/230V AC)
WEIGHT (MICROPHONE) 22.6 oz (640 g)
WEIGHT (POWER SUPPLY) 4.19 lbs (1.9 kg)
DIMENSIONS MICROPHONE: 8.27" (210.0 mm) long,
2.10" (53.4 mm) maximum body diameter
POWER SUPPLY: 8.27" (210.0 mm) W x
8.86" (225.0 mm) D x 1.73" (44.0 mm) H
OUTPUT CONNECTOR XLRM-type (on power supply)
CABLES 32.8' (10 m) cable with 6 pin XLR-type connectors for use between microphone and power supply; AC power supply cable
ACCESSORIES FURNISHED AT8560 power supply; AT8447 shock mount for 5/8"-27 threaded stands; rack-mount adapters for power supply; protective mic carrying case
I was pretty much coming from a most for your money point of view.
If you have all the money at your disposal and you are going for some legendary sound then I guess you just buy that special mic.
I run the 4060 through a Grace Design Model 101 Mic Preamp.
It ran equally well straight into my Mackie 32.8 Analog Mixer.
Only thing I ever needed for it was a Pop Filter.
Yea I saw the specs as well for the AT4060, you ever run anything else though your preamp? Sound differences ?
I pretty much made sure I bought a great Vocal Mic, Overhead Mics, Drum Mics, and suitable Guitar Mics. Im not at a point yet where I can start buying other mics to have a variety of flavors.
So unfortunately I can't compare the AT4060 to any other mics in its class.
Good Luck.
got ya, but do you ever stick it for recording guitar, acoustic, electric, or just use it as a vocal mic ? What mics do you have, im curious
I have used it as an ambient Mic for recording a guitar cab in my vocal booth.
Worked nicely for that. I have also recorded accoustic guitar. It picks up very well like an overhead would.
I haven't tryed it direct on a guitar cab yet.
I use the following mics:
AT4060 Vocals
Audix DP5 Drum Mic Kit
2 Audix D2's for Rack Toms
1 Audix D4 for Floor Toms
1 Audix D6 For Kick Drums or Large Floor Toms
1 Audix I5 for Snare (Also works great for guitar cabs, very punchy)
2 Nuemann KM184 (Matched Stereo Pair for Overheads) Phantom Powered
AKG D112 Kick Drum/Bass Guitar Cab Mic
1 Shure SM57 (Use for Guitar cabs or on Snare Top or Bottom)
1 Shure Beta57(Use for Guitar cabs or on Snare Top or Bottom)
3 Shure SM58 (Used to use these between Toms before I got the Audix mics)
1 Shure Beta58 (Sometimes used for Hand Held Vocals)
I run all mics into a 100' American Cable Company 24 Channel Snake to the Mackie 32.8 mixer, then Direct Out's to Nuendo/RME 96K 8 I/O Converter.
The AT4060 cable plugs into its rackmounted power supply, then into my Grace Model 101 Preamp, and finally to Nuendo/RME 96K 8 I/O Converter.
I would never judge a microphone by its spec sheet. Otherwise I might be led to think the Rode NT1-A is on par with the mics above and that the Coles 4038 was a stinker. :eek:
Comparing multi-pattern mics to a single pattern mic is like comparing a pickup truck to a sedan. There are reasons to choose a cardioid only and reasons to choose a multi-pattern, and there are reasons why multi-pattern mics cost more.
I have two AT4060's and they sound great, some of the best sounding mics I have. I had a Neumann M147 that I sold so that I could get another 4060. Other LDC mics I have are U87 and AKG414. But do replace the stock Sovtek 6922 tube with a JJ 6922. It sounds better than the NOS JAN versions available and almost as good as the Sylvania Gold Brand that is in my other mic. It opens the mic right up.
What do you use 2 for? Backup? Overheads?
Just curious.......
