T
Tusk
I’ve found a big problem using Cubase or Nuendo..with SoundBlaster (Audigy and Live)
all wav and mp3 file that i import in my project aren’t good because the pitch and the time it’s not the same of the original file!!! Infact the pitch is 1 tone over(than the original wav) and the time tempo about 5 bpm over also!!
I use the creative asio driver that work with 48.000 Hz sample without possibility to turn it in 44.100 Hz!!
This because using a asio Multi media driver with 44.100 Hz in project all works fine... but too much latency!!!
Ok i don’t know if the problem is The Creative Asio or the sample rate at 48.000 Hz!!!
But i’m very happy to know if it’s possible switch the sample using the creative asio!!,,or another trick to avoid this bad inconvenience.
thanx for help. Tusk.
