J
josiebethlewis2019
14 years ago I never had this many issues just setting up my MIDI keyboard, and getting it to record in any DAW. I have an issue with my ASIO driver interfering with Windows. I have watched all the tutorials, and set every sound program/device to the same 44100 Hz, but even though everything matches, including ASIO, it is impossible to get the MIDI keyboard to both play and record in the DAWs I've tried. I've tried several. Reaper, Acid Pro, Audition, Anything I can get working to arrange pre-recorded samples just refuses to allow me to record. On top of that, in spite of being assured that matching settings would get rid of the problem where YouTube videos won't play when ASIO is loaded, they still will not play when ASIO is loaded. How am I supposed to get this working? I am out of ideas and none of the videos I watched give me a working solution. If a DAW uses ASIO at all, most of the time it warns that ASIO causes instability. Some of them refuse to even allow ASIO to load at all and force you to use Windows Audio drivers, so somewhere there has to be a connection that allows both to function, I just can't seem to figure out how. None of the forum posts I've read give me a working solution. I think it boils down to needing a multi-client ASIO driver, but those seem to be elusive or built in to specific DAWs that I can't use right now. Can anyone help me figure this out? I can play any specific VST with ASIO, some work without it and use only the native windows drivers (ASIO is not even an option). One VST refuses to play inside a DAW but plays fine outside the DAW. Both ways (when they play) play with no noticeable latency at all and very quick response on the keys. But none of them work in a DAW so I can record. None of them can be recorded in Audacity. I can even load most of the VST plugins in the DAW and play them in the DAW, but none of them will record, like they refuse to do it. I can arm the track for recording and hit record, and it refuses to record the notes I play. I'm about to pull my hair out. I should not have a hardware problem. I have 64 GB of memory and a decent processor. It's a software issue and I just do not know what to do to fix it. It was not this difficult 14 years ago to get things working right. And please, don't be snarky and say "It's user error". No it's not, I have several years of experience, it is a configuration issue where I am either missing a setting somewhere that I am unaware of, or ASIO4ALL is trash and I need a true Multiclient cross-DAW ASIO driver that truly works miracles. Some VSTs require the ASIO driver to get rid of key latency or the keys do not respond correctly.
