kgirl72
Hi guys.
This may sound dumb, but after switching my XP laptop to ASIO drivers yesterday with Sonar2.2...I got to thinking.
I quit using my desktop running Windows98SE with my Sonar, because it had Windows98. I tried to upgrade to XP, so I could use WDM drivers properly, and there is a bunch of stuff that wouldn't upgrade properly. I could probably make that work still, but then again, maybe not. A lot of it was over my head...so I gave up on upgrading the OS.
Now, I told my mom I'd give her my computer (though I still like that computer) because I couldn't do the audio stuff on it properly. I got to thinking though that maybe if I go ahead and upgrade the Sonar on my desktop computer, the HP(which is still sitting at an older version), would I maybe be able to use the ASIO drivers on my Layla 24 instead of the MME drivers. And, if so, what functionality would I be missing as a result of the OS being Windows98SE?
Anyone know? The new drivers for the Layla24 have some ASIO improvements among other stuff, and supposedly even lower latency. The direct sound option I believe is to work directly with the hardware...is this correct, and therefore, I could still use the Windows98 with the ASIO drivers and enjoy a low latency system?
I'm curious. Mom wouldn't be happy, but if I could keep the computer and not buy a new one later, I'd be happy. Someone has to come out on top. Right now, all that computer is being used for is my 7-year old daughters games. That's it, and seeing as how I forked over upwards of $2000 for that entire system, about 2 years ago, not including the special Layla24 breakout box and card I purchased afterwards to work with BOTH my desktop and laptop systems...I'd rather keep it than give it away.
Any info would be greatly appreciated. I want to be able to use dxi's and monitoring for effects. If I can still expect horrible latency...I'll go ahead and give it to her, unless anyone has any other fabulous ideas.
Thanks,
Kirstin
Thanks,
Kirstin
) Input Monitoring is not driver-dependant, only latency. If your latency is usefull, then Input Monitoring should work just fine.
