Hi Phil, the transformer ratio is 10.5:1 and the Cinemag CM-2480 works nicely.
I would not recommend removing the inner screen as it will cause the capsule to shut down sooner from moist air particles coming from the vocalists breath plus the capsule will get contaminated much more easily with dirt particles.
As you stated the capsule replacement and 6072a tube upgrade will make the largest difference in sound. We also replace the electrolytic coupling capacitor with a larger mylar as electrolytics have a 20% tolerance and the low frequency response can vary between microphones. the electrolytic will also break down sooner and does not respond to fast transient hf information as quickly as the mylar cap. The Chinese "Alctron capsules" which are also used in the Telefunken RFT M16 are a bit inconsistent and can vary 2-5 db in their midrange response making some brighter sounding than others. I have been able to "tweak" some of these in and tame them a bit. I quite like a "good" original chinese ALCTRON capsule on acoustic instruments and for room microphones with its typical lift at 2.7khz.
I really like the 460 "ALCTRON" cathode follower circuit as its an improvement over the AKG C12 circuit. My original 1966 RCA tube manual states, "The use of the cathode follower circuit permits a design that has a high input impedance and high output voltage. The output impedance is quite low and provides excellent damping to the load (good design when coupling to transformers). The cathode follower circuit also yields very low distortion figures. The Peak to Peak signal voltage approaches 1.5 times the plate voltage (this means it will swing a high peak to peak output voltage than the plate coupled circuit). There is no plate resistor required in the cathode follower circuit which decreases the peak to peak output voltage available to the output transformer.
With the Peluso CEK-89/Cinemag CM-2480 and tube/capacitor upgrade the 460 will now respond like a U67. With the CEK-12 Peluso capsule and Cinemag transformer the 460 will respond like a C12/ELAM 251 and with a CEK-367 capsule it will have a Tele U47 response.
I have a client that has our CM-12 (Apex 460 with CEK-12, tube cap upgrade and Cinemag output transformer). He uses the Advanced Audio CM-12 50% of the time on vocals and his beloved Neumann 149 the other 50% of the time.
The APEX 460/
NADY TCM1150 and even the TCM-1050 are great building blocks and easily accept Peluso capsules, Cinemag transformer and some circuit upgrades.
We have upgraded many of these microphone for some very happy customers.
Best regards, Dave Thomas (Advanced Audio Microphones)
drthomas@telus.net
PhilGood said:
The only mods I know of are these:
1. Change the tube to a 12AY7 (6072A more preferable) or a 12AT7.
2. Get a better transformer. The ratio is either 8:1 or 11:1 depending on who the source of information is. Cinemag makes good trafos.
3. Replace the capsule. Something like a Peluso or better. The Peluso's are suppose to be really good. I'm about to order one or two. This will probably have the greatest effect on the sound.
4. Remove the 2 innermost layers of sceen on the grill.
5. Change the circuit from a cathode follower to a grid circuit. This is something I am planning on doing, but haven't had the time. When I do it, I will probably post how. I may just build the circuit as a C12 and see what happens, but that will be much more complicated, and I'm not sure it's worth the effort.
