P
Phil Townsend
Apex Power Supply
Actually its real easy to rebuild the supply. Besides, I've got most eveything in the junk box.
I'm also looking at taking out the zeners. They are in there to keep the output from going over 200vdc. I'm guessing here. There are 4 22 mike caps@400volts. The sims says there is a 300 plus volt overshoot at turn on. so the zeners are helping to protect the tube and capsule from over voltage. By using a choke-cap-choke-cap supply the voltages will stay below 200 or so. Typically you want to use caps in a acending order. IE: 2ufd- choke 4-ufd choke 10ufd. That last cap can be a high grade film cap NOT electrolytic. We hate those electrolytics. Rembmber the PS IS IN the signal.
There iis a 1000puff cap just after the bridge to shut the noisey diodes...Cut that guy out after installing the good low noise diodes. (I tried Cree silicon carbides in other preamps with good results but the crees slam shut like a screen door on a summer day. The slamming is like a hammer hitting the transformer...not good. So if you use the crees a bigger tranny is in order. I use snubbers as a matter of course to kill ac line noise. But becareful here cause if the snubber is not sized correctly it will make to PS soft and you will lose dynamics.
