<<You must adjust the Send pan for the track(s), and you'll be allright. >>
I was thinking that the aux's would be mono, but there is a pan... So a comp in the aux buss becomes stereo, and the track's aux pans replace the normal pans...? This might be ok after all.
<<What about this, When you are really set with the drum mix, take only the drums you want to compress, and mix them down to a stereo track, then mute the original tracks, and add your compression as a channel insert to the drums sub mix, like all the other solutions it has it's drawbacks too, but might work okay.>>
Yes, this is a good option also. And I'm doing the indivual drum comps and eq in the track inserts, so that's not an issue.
Another thing a bout the aux sends; when you go above four, CONSOLE VIEW goes to a total waste of screen space.
But that's a whole 'nother rant right?
Wayne
