Anyone interested in a shure model 315 ribbon mic?
  • Thread starter Thread starter Freudian Slip
Freudian Slip
Freudian Slip
I am going to throw this thing on ebay if there's no takers. It's a Shure 315 Ribbon mic. Looks like it needs a new ribbon installed. Ribbon has some slack in it. I have never used it. It came to me with some other old equipment and no cord. The outside is in very good shape.
Make an offer.
Shipping in the states is $10.00. Paypal works well for me.
I can send full size pic's if you want.
F.S.
Here is a picture of the back.
F.S.
I have one of those myself . . . classic mic, I love the nickel finish. I rigged an XLR connector onto mine.
Need another one;)
If I knew where to buy the ribbon matirial I'd redo it my self. I read a letter from David (?) Royer and it doesn't sound too tough. More Tedious.
I got this one along with two ev 664's. Sold those to a guy in the UK. He paid like $50.00 shipping:eek:
Well I am going to leave this on for a couple days. I will close it when I post the mic on ebay.
F.S.
Need another one;)
It's not horrible, I've reribboned mine several times :o for scientific research, that is ;) and that using 0.6 micron aluminum leaf. I'd like some 2.5 micron stuff myself, but the minimum quantities are a bit stifling.
And I don't think I can afford a second, they usually fetch a pretty penny.
....I think I got drool on myself.....wish I had the bucks to buy and reribbon that beauty...:cool:
....somebody - give that puppy a good home!
i'm interested but i dont know what a reasonable price is....
You know, it might do with a retension rather than a full reribbon . . . that can be delicate work though, as the original ribbons are quite nearly soldered on, and the solder they used was this horrible pasty stuff that doesn't flow well at all :(
damnit...i saw the "$10 for shipping", and for a second thought he was only asking $10 for the mic itself
only if, right?
Ok I opened the thing up this moring to take a look. It looks as if the ribon had broke between the ribbon and the solder point at one end. I loosened the clamp at one end and was able to get the ribbon to extend to the solder but, it looks to me as if it really needs a re-ribbon. There is not enough ribbon to pull it past the solder point to hold tension while soldering.
Man the solder they used is crap! You ain't kidding mshilarious. Only nice thing about it is that you can melt it without the wire budging in the process:D
As far as a fair price. I am not to sure either. I was thinking maybe $50.00 plus shipping. The person buying it needs to be able to repair it or plan to send it in for repair. As far as I know it needs a new ribbon and the metal screens over the ribbon removed and re-glued. Far as I know the screens are part of ribbon relacement process. I would at least to make sure there is no debris in there.
Later
F.S.
That wouldn't matter, so long as the ribbon is intact between the clamps it will work fine. It doesn't need to be soldered on, in fact that is not a good idea. The solder is just to attach the wire to the ribbon motor housing.
$50 is an unbelieveable deal, somebody better take that before I do!
err.............err..........I'm verry tempted.
mshilarious, how would one go about getting a ribbon to replace the old one.
First I think you'd need to establish whether the ribbon needs replacement rather than retensioning. Freudian, I wouldn't further tension the ribbon unless you can test it for resonance, otherwise you could overtension it--which may be reversible, but the ribbon is fragile and the more you mess with it, the more likely it will be torn.
The 315 has three layers of screening; the first is the metal grille, which is backed by silk, then the screens right in front of the ribbon. I removed all the internal screening on mine, in an effort to preserve some HF response, and I think it helped. But you would need to evaluate the condition of the screening if you intend to retain it.
Also keep in mind that this is a somewhat collectible vintage microphone, so mods can alter its value. That wouldn't include a competent reribbon, but clearly removing screening would fall into that category. When I got mine, it had plenty of issues to prevent it from being valuable, so I don't mind hacking away at it.
If you go for a pro reribbon, I think it generally runs around $125, but I don't know who is reribboning old Shures these days. Ask around, somebody will know.
If you want to try it yourself, first you'd need proper foil. I use silver leaf from an art supply store, that's not really proper material as it is very thin (0.6 micron), but it's cheap and readily available. It is very difficult to work with, but I've gotten pretty good at it.
Proper material is more like 2 micron, and it is available from some industrial supply houses. It is shockingly expensive for even a small sheet, and you need such a tiny amount (the 315 has a really small ribbon) that it is not cost-effective.
I have thought about offering a reribbon service for Chinese mics, but I haven't seen that there is demand yet. I ain't gonna do vintage ribbons as that's too much pressure :o
There I go opening my big mouth and spitting out a price:D I tried to find these used and could not. I suppose that should have meant something:rolleyes:
I figured re-ribbonned it would be worth $300.00 to $500.00 considering the shape the housing is in. Pretty much a guess based on other ribbon mic's I looked at. So I think if someone wants to take time and money to have that done then they deserve to come out good on the deal.
You could just tell us it is sold and get it repaired yourself.:D:D
Na. I woudn't feel right, plus I'm as broke as the rest of you all:) But if it doesn't go here pretty soon it is heading for ebay and you will all have a crack at it there. Could be good or bad for ya;)
F.S.
From my research this is apparently a 315S. The "S" is meaning switch I guess, for the polarity switch on it.
F.S.
That ain't no polarity switch, it's an on-off switch. The 315 was used a lot in PA systems.
Ooops I meant to say impedance switch. Brain went on auto pilot or something. Mine does not have a on off switch. At least not exposed.
F.S.
