2 more cents
Seeker of Rock said:
Always receive good advice on here, so it seems prudent that I would continue to follow. Radio Shack was out (thank God I called first!) but just got back from Best Buy and have one anti-static wrist band in possession. Now I need to do the couple of shots I missed whilst gone, and then I'll be ready to install. Thanks as always for the good advice! I'll post back if I run into any major trouble.
If this is the first time you have done this:
1. You may be suprised at how well the chip is held in its socket
2. When you start to pull it out you may hear some chrunches and crackles
3. You may want to get a small size screwdriver and slide it under one side
then the other and pry up just a little bit at a time
4. If you try to pull it up with your fingers you may have to put so much
force on it one side may come loose first, it flip over, and punch one of
the legs through your fingers. Won't damage you but does smart.
5. If you do bend one of the legs or collapse it like an accordian it can be
pulled or bent out but be gentle. You can do this about twice, then
they may break.
6. If it has a little lever on the side of the socket, this is a zif socket (zero
insertion force), release the lever and gently pull out.
7 When you unplug the chassis from the wall, you unground it (this
ASSUMES that your socket hase the ground wire hooked up at the
socket, the breaker box and to the ground rod in the ground).
8 What are you hooking the bracelet up to? I leave the chassis plugged
in, power off, and then touch the chassis often during the work. The
chips rarely have more than 10 volts, usually less on them. They will
not shock you, stay away form the power supply though and things
with heat sinks on them near the power supply. If you do hook the
anti stat up to the chassis and the chassis plugged in to gound and the
unit is leaking some power or has a bad ground or your socket is not
grounded (very common in older bldgs) you can get the shit shocked
out of you and not be able to get away till you rip the damned braclet
off.
9. Concrete is good, blue jeans are okay, especially if you used a fabric
softener or dryer sheet. Don't wear a synthetic shirt or polyester
leisure suit, but please wear something.
Last but not least, if it does not work don't blame yourself. Most of the time
this happpens it is doa.
I have been doing this for about 35 yrs and have now found most of the wrong ways to do it.
If you can find a computer savvy kid that is not hyper and has done this before with good results on a computer bios, let him/her do it.
Good luck, but you probably won't need it.
