Anybody want a 32 channel Topaz analog mixer with issue? selling cheap
  • Thread starter Thread starter jerberson12
J
jerberson12
mucis procedure
FS: Soundtracs Topaz 32 Channel Mixing Console with issue
Hello guys
Getting rid of my Soundtracs Topaz 32 Channel analog mixing console
It has 32 channels with 8 sub outputs and 2 main output, it also comes with meter bridge
The issues...
All channels are working except channel #26 which has this noise and static coming out if you use it's line input. If you use the insert or tape in, it works fine.
You will still have a good 31 channels to use
There are 2 sub outputs that are not working out of 8
Outputs 1, 3, 4, 6, 7, 8 are ok
Outputs 2, 5 are not working
The main output is working, thats the important pair
The led meter lights for the output only works at the lower green part. The red leds at the higher portion of the led meter does not lit.
All yours if you know how to fix it
asking $600
You pick up this thing is heavy
San Diego area
Bump
read 1st post or read below
Hello guys
The issues...
asking $600
San Diego area
