Anybody know what the bit depth on the BR1600's .VR8 files are?
  • Thread starter Thread starter jedblue
jedblue
jedblue
beep beep beep beep beep
If, as the specs say, they are 24 bit AD, 24 bit processing and mixing and 24 bit DA then I suspect the .VR8's are 24 bit? Then maybe they are only converted down to 16 bit when output as a .wav or on the cd?
Well I have managed to answer my own question by successfully importing a BR1600 .VR8 file into Audacity as a raw file import. It imports successfully as a signed, 16 bit pcm, little-endian, 44.1kHz file. Imported at 24 bit, it was a massively clipped, payable but unlistenable mess.
So now I know for sure. It is storing the audio data at 16 bit. I can understand the 24 bit delta sigma AD oversampling but I have no idea what they are refering to in the specs in regards to 24 bit processing / mixing / DA unless they are only talking about the BR1600 being used as a mixer and not as a recording device and are just trying to impress us with it's pseudo 24 bit credentials.
So, definitely a 16 bit recorder.
GGGGggggg
