Any reccomendations for building a new DW ?
  • Thread starter Thread starter Warda
W
Warda
I am about to build a new DAW, any comments / suggestions on below
building idea ?
* P4C800-E E, Deluxe
* Intel P4, boxed 800mhz
* CPU cooler Zalman, CNPS 7000 A cu
* 2 Gig RAM, ECC needed ??
* Power supply Zalman, ZM 400A-APF
* Matrox, P 650, no fan dual head Dig + Analog.
* Box, Thermaltake, Tsunami VA3000BWA
* DVD writer
Thanks !
warda
Sounds good.
Non ECC is fine.
You'll want at least two 7200 RPM HDD's, IDE ATA 100/133 will do fine. Or, if you really wanted you could use SATA drives via the South Bridge controller.
I would imagine that DVD writer will also burn CD's?
OK, thanks, yes I was thinking about SATA drives, I have read that 3 is even better (one system + programs, one samples, one for audio files) ?
Indeed I intended DVD/CD Re-Writer.
I have one UAD card, probably two in the future.
Cheers,
Warda
