Antares Harmony Engine evo problem
  • Thread starter Thread starter BriamJH
B
BriamJH
Active member
Hi: I have downloaded the Antares Harmony Engine evo free version. However, when I try to install it, I encounter problems. If anyone has had this issue and knows a solution I would be grateful for help. I have attached the various screenshots as I proceeded through the download process. Many thanks, Brian
From the looks of your screen, you are on Windows, I can't tell what version. You might want to add this information.
Try to unzip it with admin. Either that or your virus software is preventing the exe from being copied. Just a guess.
Many thanks. When I hit the full zipped file, three files emerged. One was the zip code 123. However, when I tried to extract the main files I was not asked for the zip code. (I am using Windows 10). I will keep on trying. Brian
Problem solved. I downloaded WINRAR. It requested the zip code and completed the installation. Works fine. Many thanks for your earlier comment. Brian
