JimmyS1969
MOODerator
Is it worth the time to angle an opposing wall during construction reduce standing waves? If so, what is a worthy angle?
I am about to finish a 14' X 25' concrete walled room to be used as a drums mostly, tracking room. I plan to fill the 24" X 12" open joist ceiling with fluffy stuff and cover with wire and cloth. Floor is concrete. I have every opportunity to build the walls/corners/doors as I wish here. Isolation is not a concern other than access to control room, which will be a double wall/door deal.
Concave or varied angles in build on certain walls? This is not a mixing room so, is balance not an issue? I have constructed uneven (this is not the right word) walls in a studio previously based on a paid designers recommendation; though this guy also placed the control room desk on the long end of the room with no absorbers whatsoever and placed foam on the rear wall. * I therefore do not trust his knowledge based upon what I have learned in this forum, as well as his non-use of reflective panels and bass traps that have worked in my control room wonderfully. {Btw, that wall looks friggen cool, (though I'm not sure it has a worthy effect); Basically the bottom plate is parallel to the 19' brick wall behind desk, with the top plate and studs/drywall extend into the room from the center, 20" on either side at side walls.}
I have not found info regarding an optimal build design for a space this size, specific to when the whole room is being used for drum and instrument tracking. I know this isn't an ideal, large room for drums, but if there are benefits to adding angles, built in corner traps or niches, or any construction level options that would optimize my space? That is my query. Any experience in this area would be greatly appreciated.
If anyone with this knowledge lives in Denver CO, I would be very willing to pay for consultation.
Thanks in advance and sorry for the long winded question,
Jimmy
Jimmy
