D
darkecho
What are the benefits of an analog knob for Studio Monitors volume over the computers soundcards digital volume sliders?
Farview said:Every 6db you turn down the volume, you lose 1 bit of resolution. It also gives you one more way to screw up your gain staging.
Farview said:In that instance, no, you are not losing resolution. You only lose resolution when you come out of the DA converters too quietly, like when you are using your master fader as your monitors volume control.
You do have a bigger problem however. You are obviously recording too hot. I have projects with over 50 tracks and I don't have to turn down the master fader...ever.
You should be recording at line level, which means your tracks should average about -18dbfs. This will take care of the problem.
Recording too hot just makes your recordings sound small and lifeless. It taxes the preamps and other stuff in the analog chain leading up to the converters. It also screws with the plugins you are using in your DAW.superspit said:much appreciated......I thankyou.
I guess that recording too hot can result in the same net effect???
Regards,
Superspit!
Yes, that is about what you need to do.darkecho said:what is a good method of figuring out if you are recording at a good level or too hot?
if a guitar, maybe just playing a nice long power chord and adjust the preamp volume until it levels out at -18 on the PC?
would you do a similar thing with a keyboard, just hold out a nice common (to your style of playing) chord, and adjust the keyboard volume until in the progeam you are using, the volume is about -18?
