Amp output affected by speaker load.
  • Thread starter Thread starter den0744
D
den0744
I have a transistor amp rated at 200 watts RMS into 8 ohms. What would the output be for 14 ohms or how to calculate it ?
Roughly, half, though not exactly. Here's a formula...
1. Ohm's Law deals with the relationship between voltage and current in an ideal conductor. This relationship states that:
The potential difference (voltage) across an ideal conductor is proportional to the current through it.
The constant of proportionality is called the "resistance", R.
Ohm's Law is given by:
V = I R
where V is the potential difference between two points which include a resistance R. I is the current flowing through the resistance.
How are you getting 14 ohms?
16 ohms (much more common) will give you 100 watts. You won't notice a volume difference all things being equal.
