Amp Help(behringer b2031p monitors)
  • Thread starter Thread starter misscc803
misscc803
misscc803
Tech Support Specialist
Do I have to use an 150amp with the Behringer B2031P or can I use something a little bigger?
What should be my max? I need to know cause I dont want to blow them.
Information:
Following in the footsteps of the highly acclaimed TRUTH B2031 active monitors, the passive B2031P 2-way studio reference monitor is for those who already have a high-quality amplifier. The B2031P delivers very neutral sound, has an extremely flat frequency response (55 Hz - 21 kHz) and can handle up to 150 Watts of power.
Thanks
Nicole
you can go with a higher powered amp if that's what you have. at reasonable listening levels you are unlikely to do any damage. in anycase, your ears should pick out when the speakers are being over-driven.
ok thanks. Just wanted to be certain. Appreciate it dearly.
Nicole
