D
DM1
I'm building some 2'x4' panels for my first reflection points. A simple pine frame with 4" Roxul S'n'S, wrapped in muslin. However, I feel the frame needs a rigid back for support.
Most of what I've read suggests that the backing should non-rigid (notably, Ethan's oft-repeated advice that a plywood backing reflects sound and negates the benefit of an additional air gap.) Is this true of all rigid materials? Would pegboard, with all its holes, be OK in place of plywood?
And if not, what alternatives are there for strengthening the frame without affecting the acoustic properties?
Now, if you get to 4X4 size panels, you will need a few angled pcs at the corners like MS says. Some thin plywwod does the trick.
