I just got a Yorkville SR300 studio amp. It has great specs, and sounds great. I highly recommend this amp.
http://www.yorkville.com/default.asp?section=3&level2=11&level3=
Specs:
Amplifier class A / B
Coninuous Average Power @ 8 Ohms BCD (Watts) 110 (x2)
Coninuous Average Power @ 4 Ohms BCD (Watts) 150 (x2)
Coninuous Average Power @ 2 Ohms BCD (Watts) NA
Continuous Average Power Bridged BCD (Watts) NA
Burst Average Power @ 8 Ohms BCD (Watts) 125 (x2)
Burst Average Power @ 4 Ohms BCD (Watts) 195 (x2)
Burst Average Power @ 2 Ohms BCD (Watts) NA
Burst Average Power Bridged BCD (Watts) NA
Frequency Response (Hz, +/- 1dB) 20-20,000
Hum and Noise (un / Aweighted -dB) -95 / -98
THD -1kHz- 4 OHMS less than 0.015%
THD - 20Hz-20kHz, 4 Ohms less than 0.15%
Slew Rate (V/uS) 20
Slew Rate Bridged (V/uS) NA
Damping Factor (30 Hz - 400 Hz @ 8 Ohms) 400
Crosstalk (1kHz / 20Hz-20kHz) -60 / -40
Input Impedance - Bal/Unbal (Ohms) 20,000/10,000
Input Sensitivity (Vrms) For Full Power Out 1.4 V
Max Voltage Gain (dB) 25
CMRR @ 60Hz (min/typ) 54/66 dB
Stereo / Mono / Bridge (S/M/B) S
Protection DC,Load,Thermal
Limiter Peak / Average
High Pass Filter
35Hz, 12dB Octave
Cooling Passive Convection
Inputs - 1/4" Jacks 2
Outputs - Binding Post 2
Outputs - 1/4" Jacks 2
Power Consumption (typ/max) 200/500 Watts
Rack Spaces 2
Transformer Type Toroidal
Exterior Finish Baked, Black Painted
Dimensions (DWH /D fm ears, inches) 13.1x19x3.5/12.1
Dimensions (DWH /D fm ears, cm) 33.3x48.3x8.9/31
Weight (lbs / kg) 22.5/10.25
