J
Jude2010
which is better?
Well I can't speak for the M Audio, but I have an Alesis io2 Express hooked up to my PC running Reaper and it's just brilliant. The preamps and A/Ds are top notch and using ASIO drivers I have no latency problems whatsoever.
I'm using it with 2 large diaphgram condenser mics, and unlike some of these small interfaces the io2's 48v phantom power stays at 48v with both mics connected, (with a previous Lexicon interface I used its 48v dropped to 32 volts with two mics plugged in). I occasionally use the line input with an external fx box to record electric guitar on one channel with the mic on the other. The thing I particularly like is that my gain structure with the io2 is spot on. With the preamp gains set about mid travel and all the faders on my DAW set nominal I'm recording at an average of around -18dB which is exactly where I want it. I have a roll-up keyboard plugged into the MIDI in on the io2, though I don't use it that much, maybe to tune up my sax quartet when we have a recording session, or maybe to work out some harmonies if I'm tinkering with quartet arrangements.
The io2 is a great little interface and I'd recommend it to anyone.
