Alesis HD24
  • Thread starter Thread starter vicomazica
V
vicomazica
I bought a used ADAT HD 24 and I am trying to record 22 tracks using 3 Pipe line (optical) Inputs. When I arm record the 22 tracks, I get only the first 8 and the rest are duplicates for the first 8 tracks. I failed to record more than 8 tracks. Any one can help?
The HD24 can be set to different input modes to accommodate mixers with 2-bus, 4-bus, 8-bus, 12-bus or 24-bus (or direct output) architecture. You recorder sounds like it's in 8-bus mode which repeats the first 8 inputs on the next two banks of 8 tracks. On page 22 of your manual it tells you how to change the input mode to 24-bus by pressing Input Select until the display reads "Select Audio Input Tracks" then pressing track select (arming button) 13.
Hi Boulder Sound Guy
Thank you soooo much for your answer. This is an amazing answer to me which has solved my problem. You are a great expert.
Thanks again
