I like to use the D112 in combination with a small diaphragm condenser mic(usually an MC-012) on the beater on the front head. I place the D112 just inside the hole on the kick head, and then place the 012 right next to the beater on the front head. Make sure you have your drummer play after you place the mic to make sure it doesn't interfere with his playing. The beater mic captures the slap attack of the beater, while the D112 catches the boom of the kick. You can blend these two together and you get a kick that is punchy and boomy. And it usually doesn't require much eq or compression to make it sound better.
