Akg D112 And Phantom Power
  • Thread starter Thread starter rightbrainnow
R
rightbrainnow
what mics do you have to worry about phantom power hurting? that was horrible sentence structure. im particularly concerned with the akg d112 .
Practicly none (unless you've rewired one incorrectly).
The D112 will not be harmed, neither will any other dynamic mic.
One caveat, though. You should generally avoid plugging microphones (including dynamic mics) into a mixer or whatever while phantom power is on.
Turn off phantom and allow it to discharge for... probably at least a minute or so before plugging a mic into a jack that was previously empty or unplugging a dynamic mic from a previously hot jack. If the jack had a condenser microphone plugged into it, a second or two should probably be sufficient to dissipate any remaining charge, I would think, but if you still hear output from the condenser mic reaching the board, you haven't waited long enough. :D
