H
hgoodspeed
Hello there, I just recently purchased a lovely little AIWA TP-40 and though it plays the existing tape perfectly (older recordings from pervious owner) when I try recording audio (with a little Sony PC-62 mic) the tape picks up my voice but dramatically fades to little more than a whisper after 5 or 6 seconds and is reduced to a barely audible level.
I'm not sure how old the tape is, if that could be an issue, but I'm assuming something internal, a wire or something, is not functioning correctly and could be easily replaced. The device is quite old, so I'm assuming something inside has to be a little corroded. I could open it up, but seeing as how that seems to be a bit of an undertaking I thought I'd ask you all if you had any idea of what it could be.
I think this is probably a common problem with older equipment that is being used for the first time in a long time. Thanks a lot for any advice or help you can give me, I'm certainly not above bringing this to a retailer/shop if it requires it.
-Hiller
-Hiller
