rayc
retroreprobate
Hello Folks,
Ido recently asked for the opportunity to rerecord the solo for this track.
http://www.soundclick.com/util/getplayer.m3u?id=7302598&q=hi
Upon inserting the new guitar line into the project I discovered a problem. I'd recorded the song using the free spin audio VST wrapper - which is quite good BUT it's not universally compatible & annoyingly doesn't remember the VST or settings when the project is reloaded. I've also moved on to the cakewalk wrapper which is pretty good.
Between the two I'd lost all my settings & sequence of VSTs.
I've had to run from memory to try to recreate the original mix.
I gave up & decided to do a complete remix and rock the tune up a little more.
As a result I need feedback.
The four main changes are the new solo, a little less bass guitar, a little more of the distorted guitar and the use on the final stereo bus of glaceverb final mix reverb + Classic Limiter + a tiny cut to the mid range.
Any suggestions, recommendations or comments gratefully received.
