Sohail - there's loads of pointless chatter going on in the Tone Thread so I'll post these clips here so you can find them more easily:
OK, here's some very high gain tones using a Boss DS1 and a Boss SD1 - both should be cheap and easily available in Kathmandu.
The DS1 is set with the level and tone both at about 12 O'Clock.
High Gain is with the gain all the way up, Medium Gain is with the gain somewhere between half and three quarters.
The DS1 will get very wet and mushy if left like this so I have the SD1 going into it with the tone just below 12 O'Clock, the level on full and the gain on zero. This compresses it all and tightens up the bass end so it doesn't turn into too much of a mushy mess.
Low volume is TV volume, High Volume is my normal recording volume. These actually sound better than I expected they would. They're all through the clean channel of my Blackstar but given that they're just pedals through a clean channel they shouldn't sound all that different through any half decent clean channel.
View attachment Low Vol Hi Gain.mp3
View attachment Low Vol Hi Gain Double.mp3
View attachment High Vol High Gain.mp3
View attachment High Vol High Gain Double.mp3
View attachment High Vol Med Gain.mp3
View attachment High Vol Med Gain Double.mp3
My personal favourite is Medium Gain, High Volume. Just playing a little more to myself this morning using this set up it was apparent that you start to lose note separation when playing quicker riffs with the higher gain setting. That's a general rule you can use as a starting point too. Try using more volume and a little less gain than you think you need. What sounds great at TV volume will sound messy shit at band practice volume.
