advice needed for newbie
  • Thread starter Thread starter willow
W
willow
i'm a professional drummer, but i know very little on recording.
my brother can give me sonar 4 producer and i will be getting a 2ghz puter soon. (i have the mics already)
i'm just wondering which way i should go for an economic way to record my drums (8 mics) and add other instruments later.
should i buy an interface for my puter or should i get an all-in-one digital multi-tracker?
which would be easier to learn and cheaper to buy??
thanks
An interface with 8 pre amps would be the cheapest way for you. I think the Presonus Firepod does that. Ive never hsed it. I have used the MOTU 896 (which has built in pres), which I really liked.
Either way, you gotta have 8 inputs and you gotta have pre amps for microphones to work. If you already have, say, a mixer with 8 pre amps and channel outs, you could just get an 8 input card. Lots of those out there.
H2H
It really depends on the level of control you are looking for.... and your budget ;)
You could get a cheap external mixer for your drums and then take it into a two channel sound card. This would mean that you could only control levels of each drum mic at the board - once it was printed to the recording, that is it! Same goes for other instruments too.
So if your budget can stand it, an 8 channel PC sound card would be great. I guess if you are a pro-drummer you would need to make the rght investment. You might like to check out the Yamaha 01X:
http://www.yamahasynth.com/products/01x/index.html
This makes an ideal interface to a DAW.
Good luck! :)
Lets say you spend $3000 for a multitracker, Tascam maybe. The preamps are good but not great. The recording device will be very good. You still have to spend around $1000 for marginally good mics, another $500 in mic stands and cables.
After maybe a year of learning how to use the compression and effects to match professional CDs you still notice that your not quite getting that top of the line sound you hear from professionally done tracks.
The delta here is the preamps, front end compression and highly expensive microphones pros use, and also equally important is the actual recording space for your drums. This will in fact be your biggest challenge, finding a decent drum room for recording.
In the end you will have spent around $4500, had a lot of fun, learned a ton of things but still not be able to quite produce CD quality. I know all this because my drummer is going through this same process of examination. Here is my opinion on all this.
Get Toontracks Vintage and Custom drum software and pick up a reasonably nice midi drum kit. You will come in at 1/4 to 1/2 the price of the above method. As all of Toontrack drums where recorded with Neve or API preamps, top notch Neumann mics and others, it will sound better than anything you can produce with semi-pro gear. Another thing, you don't have to spend time becoming an engineer and can get immediate, world class results. Last, they recorded their samples in very high scale drum rooms in pro studios.
If you want to make music and get immediate results, a midi tracking drum kit can save an immense amount of time, money and produce much better sound results. Wouldn't you want to have access to multiple drum kits recorded with top quality gear than your single drum set recorded in you garage?
Vintage and Custom - $300
Midi trigger drum kit - $1000
You have the Computer and Sonar, sounds like you are done. Lower cost, high end results.
