Advice for "brain"
  • Thread starter Thread starter RVLVNGDRS
R
RVLVNGDRS
Hopefully we're all on the same page with the word "brain" here. :p
Looking for something in the 300$-400$ range.
It's not for a complete electronic setup, it's just for one trigger i have in my acoustic kit. So im not looking for something with "drum sounds" necessarily, but more for sounds...different sounds.
Can anyone recommend something?
You can get a used Alesis DM5 on Ebay for under $300 these days. I wouldn't recommend it for killer drum sounds (for that I'd go with Roland) but for your needs it should be just the ticket you're looking for.
I would agree an Alesis DM5 (or even a D4) would meet your buget. Keep in mind - in additon to the cost of the brain you need pads and a way to mount the pads (all come with additional costs)
Depending on the sounds you want/need, the space you have (assuming you want to place the e-drums with your accoustics) and your playing style - you could even consider some of the tabletop "consumer" units.
I used a Yamaha DD14 for a couple of years - simply to add latin percussion sounds to my kit The pads were only 4" and the case was plastic (so I had to use some care in handling and sticking) and I had to canabalize a snare basket to mount it with my kit - but it did the job until I moved to a drum kat and later to the Roland.
Go to the wizard, surely he could give you a brain.
Ok, i had to. Anyhoo the Roland TD-6 is decent for the price. It's not quite as adjustable as the higher end Roland brains. But has most of the same sounds.
that part is already taken care of, and it's well placed and all...
as for the DM5, wow...i didn't know i could get it for that price
thanks for the advice
maybe someone can suggest something else?
