G
giopad65
Hi all,
For my occasional concert recordings I bought a Fireface 400 some time ago, thinking that two pres were enough for plain stereo recordings. Then I added a DAV BG-1 stereo pre to the equipment, to ensure a couple more channels to be managed.
Now I am thinking of increasing the simultanous tracks I can record.
I thought of getting myself a Quadmic, since I think the standard RME pres are not that bad (I need clear sound because I record ancient music, played by a small choir with some acoustic instruments). The Quadmic should go into the Fireface 400 through the line inputs.
Then somebody at a local music store suggested me to get a multiple pre interface that can go into the Fireface 400 via ADAT: possible choices are Focusrite OctoPre MK II and Motu 8pre.
Do you think that adding a second audio interface with plenty of pres is a good idea?
Would you rather add analog pres that run into the line inputs of the Fireface?
In this case, what reasonably priced pres do you suggest?
As I wrote, bear in mind that I aim at clear, neutral sound.
Thank you all very much.
