adding Compression inline or threw insert????
  • Thread starter Thread starter detuned6
D
detuned6
Metal dude
Ok this final question will wrap all my prevous threads-
after tracking, i send each channel to my mixer(behringer mx2004a) and i add effects, compression, eq etc. Now if im adding compression where should i do it ? threw the mixer insert or between multitracker out to mixer channel??? Both ways i would be adding compression pre eq.(track rat said the behringer inserts are wired pre eq) so since they are the same does it matter where i atatch the compression?? which would be better at avoiding any signal loss???
Thanks!
I'd use the channel inserts to put a compressor on an individual track.
track rat
so threw channel insert the compression would be pre eq, good for boosting frequences(as fenix said- cutting freq, eq then compress) ??? yeah???
Through the insert would be compression first, then to the EQ portion of the circuit.
