Buck62
噛んでくれ
I have an Epiphone Valve Jr combo with the 8" stock speaker. I swapped the stock Sovtek tubes with a TungSol 12AX7 and a JJ EL84 and it sounds great, with better punch and more of a sweet, musical chime to it. The only thing lacking now is that I'd like a little more low end, like you get with a 12" speaker. I was thinking that swapping out the stock speaker to a better one, like a Weber, might help, but not provide the beefier low end I'm looking for, to record with.
The stock speaker is a 4-ohm speaker. I don't want to get rediculous with spending a bunch of $$... I just want something pretty good that does the job pretty well without breaking the bank. A brand new cabinet is out of the question, because they cost too much. From what I've read, newer VJ combos like mine also have an extra wire or two so the output can be converted to 8 ohms. Is this a simple conversion?
Maybe you guys can give me some ideas on the best options here.
, I am assuming a constant voltage across the output, which may not be the case. Actually, I don't think I'd use more than one output terminal at a time, or connect them together, without knowing how the transformer secondaries were wound.
