Jack Russell
I smell home cookin!
I'm comparing specs on LX20 and XT20 ADATs. These are mostly the same:
LX20:
8 audio channels
20-bit linear codec
64X oversampling
Record (A/D) 20-bit
Play (D/A) 20-bit
44.1/48kHz selectable sample rates
20Hz-20kHz response
97dB dynamic range
Distortion 0.009% THD
Analog I/O: 16 RCA (8 in, 8 out)
Digital I/O: 8-channel ADAT optical (1 in, 1 out)
Click Here to Get Your Alesis ADAT LX20 20-Bit Digital
Recorder
XT20:
8 audio channels
20-bit linear codec
128X oversampling
Record (A/D) 20-bit
Play (D/A) 20-bit
20Hz-20kHz response
97dB dynamic range
Distortion 0.003% THD
Analog I/O: (balanced) 1 ELCO connector (I/0);
(unbalanced) 16 RCA (8 in, 8 out)
The main difference is the oversampling rate and distortion (in bold). Does the oversampling matter when you play a tape recorded in the LX20 in the XT20, or vice versa?
Can anyone actually hear the difference in distortion between 0.009% and 0.003% THD?
Any other thoughts about these two machines?
LX20:
8 audio channels
20-bit linear codec
64X oversampling
Record (A/D) 20-bit
Play (D/A) 20-bit
20Hz-20kHz response
97dB dynamic range
Recorder
XT20:
8 audio channels
20-bit linear codec
128X oversampling
Record (A/D) 20-bit
Play (D/A) 20-bit
20Hz-20kHz response
97dB dynamic range
