I've posted the following elsewhere, but I'll repeat it here for convenience:
I read a lot of huffing and puffing about
acoustic guitar recording strategies, and, to be honest, it caused me a lot of heartache for a while. I describe below how I ended up for my new cd, and beyond. (Note this is primarily intented for solo guitar, or guitar and vox tracked separately.)
I'm afraid I've given up entirely on spaced mic techniques for guitar recording. I only use X/Y with SDCs. (I would try mid-side, but I don't have a figure-8 mic.)
My reasons for this are three-fold:
1. When I listen back through a hi-fi system at normal listening distance, a guitar recorded with a spaced technique sounds unrealistically big. In fact it sounds about 12ft wide. This might sound impressive to some, but it makes me nauseous.
2. Phase cancellation. No matter how big it sounds in stereo, if I hit the mono button, the middle of the guitar disappears, leaving the sides hovering disembodied in space. More nausea. Maybe that has more to do with my skill at setting up a spaced pair, but for the other two reasons, It's now academic.
3. To a listener in an audience any further than 6 feet away, the guitar is a mono source. Any stereo information is by virtue of room reflections.
This is what I've settled with: I use two Neumann KM 184s in an X/Y setup about 18" from the guitar. These aren't matched, but I don't consider that so important. I used ORTF for a long time but the killer was phase cancellation - it just didn't translate to mono without a lot of stuff disappearing! Not good if I aspired to some radio plays! I had actually recorded more than 30 guitar parts using ORTF before being forced to admit it wasn't going to work for me and had to abandon them and start again using X/Y. Now, X/Y can appear to give a very (too) tight stereo image, but it truth I find it more accurate - the guitar doesn't sound 20 feet wide when played through a hi-fi! And anyway, if the image needs a bit of stretching, I can use a bit of mid-side processing in the box. I'm considering getting a figure-of-8 and do some M/S for real for the next record. Or two, and do Blumlein. This gear purchasing never stops.
(Now an A/B setup with mics pointed at saddle & neck / body joint
can sound fantastic - just make sure you audition in mono. Mono-compatabililty doesn't matter to a lot of folks, but it does to me - so I don't use it.)
More for general interest, here's my signal path:
Mics: KM 184s (guitar); Audio Technica AT 4033 (vox)
Pre-amps: per Allen & Heath GS3 console
Soundcard: RME Multiface
Software: Cubase SL
Plug-ins: Voxengo and Kjaerhus dynamics and Voxengo convolution reverb.
Monitoring: Mission Cyrus amp and JBL 4208 monitors (it'll do for now!!)
Phones: Sennheisser and Beyerdynamic
PC: self-built using QuietPC case, Seagate Barracuda HDDs, AMD 64 CPU, Zalman heatsinks, fans and controller.
The following is new to this thread:
1. I recommend you record the guitars with a very tight stereo image with a view to panning them quite far apart. If each guitar has a wide stereo image, and / or panned close together, I suggest the whole thing could become a bit mushy with guitars' individual voices getting lost.
2. I would consider EQ-ing each guitar differently to further differentiate between the instruments. Try to find the each guitar's best and worst tonal characteristics (all acoustic guitars have them) and EQ to suit. Or more generally: if you cut a bit of bass from one guitar, compenstate with a boost in the same are, to the same degree, in the other. Ditto top-end cuts & boosts.
3. I would consider using reverb creatively to further create a sense of distance between the guitars - perhaps a touch more on one, than the other. Differential EQ can also add a sense of distance: brighter = closer, darker = further away.
4. I wouldn't propose to compress the guitars differently (if you need to use it at all.) That IMHO would "unglue" the "perfomance".
Please use the EQs and reverbs and compressors sparingly. I know from bitter experience that recording and mixing acoustic guitars requires patience and a gentle hand. Acoustic guitars don't respond well to extreme settings in any department.
Hope this helps.
Good luck!
