C
Codeseven
If your planning on using samples to replace your drums, should that be kept in mind when setting up the kit. For example, the drums you plan on replacing with a sample, shouldn’t you think of it more as a trigger rather than a perfectly tuned resonating drum? Wouldn’t it be better if there were little resonance so that when a gate is used to reduce bleed a more defined hit could be created for accurate triggering. I plan on using Oxford Drum Gate, to clean up say, a snare track, and then send it to Slate Trigger 2 for replacement samples. I want the hits to be as defined as possible for trigger accuracy, so I’m not worried about tone or resonance, correct? Thanks
