A lot of you guys are saying "I used it for a while", "it's great for starters", "it's cool if you're new", "I use it from time to time"...
which implies that there are some greater programs... and what I want to know is, what are some better programs that are more suitable for people who aren't just starting out?
Catch my drift? I'm looking for higher-end ones..
depends on what you want to do. if you don't use midi at all, i'ld say it's not worth switching. even when i've worked with protools, i didn't use the automating faders.
oh! and i hate that after you've put automation on a track, the faders are worthless. you'll put some automation on, then adjust the track level, and it will ignore what you just did, and go to where ever the automation line is. that frustrated me to no end in class when my mix was played and it was totally not like i mixed. i was just so used to acid.
in acid the faders and automation aren't the same thing. so you can automate and then turn the entire track down or up after that.
protools does have track grouping for editing purposes, but a simple hold of your shift key and 2 clicks and you can adjust volumes pretty quickly in acid.
if you're using midi protools is a lot better for editing, as it's not so easy in acid. (i haven't used much midi in acid, besides using a click, or an already programed file)
the newest version of protools did have an editable click track. so you could make the song retard without putting in a million tempo markings. oh...and in acid, for me at least, recording over tempo changes messed up the sampling for me. i did it some time ago, and only once, so i guess i didn't see if i could fix it..but protools doesn't do that.
so probably consider what you're actually going to be using and wanting to upgrade. acid for me is perfect. i hate midi and would never ever ever want it in my recording, and i don't do tempo changes much, and if i want to retard i'll just fade out my click track. my familiarity with acid trumps any advantage to going to protools.
