acid and cool edit pro
  • Thread starter Thread starter Big Ted 167
B
Big Ted 167
Ok, I have acid xpress and cool edit pro. Now for syncing my loops it is very simple to do, but when I save on the express I cant seem to save to .wav. What are my options on saving my individual tracks so I can load them into cooledit for multitracking.
iam not sure about acid express but you should be able to save as a wave file when you go to save hit the arrow down button and it should show you a list files in which to save it should have .wav in the list.and if acid express has an audio editor you can choose cool edit as that.check acid 2.0 it has more feature.
Acid Pro
I don't know about Acid Express but in Acid Pro I used the export function to save my files in .wav format
can't do it
Acid xpress has no provision to export toa wave file
jump up to Acid Music...around 80 bucks...well worth it.
If you have another wav editor...like Goldwave..which I hightly recommend...you could
create a new file in goldwave
start recording
switch to acid
solo the track
record a new wav file in Goldwave.
a workaround...that works
akimbo
