cincy_kid
Active member
Ok, so now I have my 12 pieces of OC 703 Rigid Fiberglass - 2" thick (2' x 4' sheets). I will be building 12 frames this weekend that will be covered in fabric and constructed almost identically to the way db did it here .
Unfortunately my room has ceilings that are only a little over 7' so I cant build any tall 8' panels for the corners and I dont want to cut the 703 down to size, so I will deal with 12 panels all the same size that are framed with 1x4 wood giving about a 2" gap from the wall behind each one.
So, heres my question. I am looking for advice on the best way to arrange the 12 panels once constructed.
Here is my current plan (see diagram):
I will be mixing / listening from the desk. I will be recording vocals in the bottom left corner and guitar amp in the bottom right hand corner (or vice versa). I have 3 clouds total, 1 positioned over each recording area as well as above the desk near the monitors.
The rest of the panels are either in the corners or along the sides of the walls as you see in the picture. In the diagram, if they are longer like in the middle of the 3 long walls, then I have them hanging 4' wide and 2' high (all about in the middle of the wall height wise). The shorter orange bars in the pics represent 2' wide and 4' high. Do these look like they are ok or does anyone have any advice / suggestions to better utilize the 12 panels?
Also, for the ones in the corners (behind the monitors), since the are 2' x 4' and dont stretch the entire height of the room, should they be up to the ceiling (kind of like bass traps) or should they be monitor level or even lower?
Thanks again for any help you may provide.
I will be posting pics as i construct this room as promised in previous threads.
- Cincy_Kid
- Cincy_Kid
