R
Rico 52
I have a system 8.............I have not used it in years and was thinking of setting it up again. It was used -w- a tascam Ms-16. Now it will be used -w Da-38's. Any comments on this unit. Are the pre's good. I am currently using an Alesis in line 16 board and outboard pre's. I have had good results mixing with the alesis and the monitoring section is very user friendly. Is it worth setting up the ABH sytem 8? It would be used for mixing as I will continue to use the outboard stuff. The MS-16 ran at 30 ips -w- no DBX. I always thought it lacked bass response.........and somehow attributed that to the system 8.............but was not sure... so when I got the DA-38's the Sytem 8 wound up in the closet. I never tried the system 8 -w- the Da-38's
rico
rico
