jdier
Hoping someone here can help me out? I have been having some problems getting my two Q10's to work in my machine for some time now. Curious if anyone here has any info or suggestions...
Machine:
mobo: Iwill MPX2 Dual AMD motherboard (AMD 760MPX chipset)
chip: AMD MP 2200 (x2)
power: Enermax 430W
mem: Samsung 1024meg ECC registered
HDD: Western digital 20GB (OS) Western digital 80GB (Audio) >> Both 7200rpm, Audio has 8mb cache
Vid: Matrox G450 32 Meg Dual Head
NIC: D-LINK Fast Ethernet
OS: XP Pro
Aardvark Q10 (x2) running 7.04 drivers
Sonar 2.2 XL
(System is less than 2 months old and has never been used for anything but this. I have not other softwares or virus scanners or printers, modems installed or running. The machine is also not networked or connected to internet. The only cards ever in the machine are the ones listed above.)
This is where I started. During the past weeks I have done the following:
1. Removed the NIC for good.
2. Moved the Q10's until they were in slots where they DO NOT share IRQs with any other device
3. Got rid of USB mouse, moved to PS2 mouse
4. Uninstalled 7.04 drivers and replaced with new drivers provided by Aardvark.
5. Cleaned registry of all legacy Aardvark info
6. Tried ASIO drivers
7. Tried MME drivers
Things I have not done:
1. Disable ACPI - This I do not want to do based on difficulties that I expect would come from this due to the machine being a dual processor.
2. New Video Card - I do not have another card, but I think I am going to downgrade the drivers on this card to Generic VGA 1600 x 1200. This should be a good test if the Graphics card is the problem (which is one of Aardvark's suggested causes of my problems, the Matrox Card.)
The one other thing that I have not done is try to run the machine with only one Q10.
I am very reluctant to do this because the system is of no use to me with only 8 ins.
Next time I am at the machine I am going to try it because Aardvark explained that this would help them diagnose if my difficulties were related to the two card configuration.
I have the best luck and most stability running the new drivers and using the settings that the Sonar Wave Profiler suggests (this is the WDM/A|WDM driver setting.)
So, my symtoms are lock ups and crashes. At first they seemed to come only when we were plugging/unplugging XLR cables from the unit, setting volume levels or switching control panels views. Some times it would lock just launching the Q10 control panel. Now we can get it to crash many different ways and many times it will just crash on it's own.
Most of the time there is just a pause in system responsiveness followed by the inputs on the Aardvark card dying. In some cases I will get an Aardvark error, but most of the time it will just stop working. I can restart the service and relaunch Sonar in about 50% of the cases and be back up and running without a reboot. It seems if the Aardvarks die and I do not get the service restarted pretty quick one of two problems will pop up: 1. The services will not restart, or 2. Sonar will not quit.
The one other glitch that I have every once in a while (once every 3 hours) is that Sonar CPU usage will spike (not gradual, but very quickly) to 50%. When I try to shut Sonar down it will either generate a Sonar unrecoverable error or it will appear to shut down correctly. However, in either of these cases when I try to launch Sonar again, it will not launch. If I check task manager, I will see that while the Application is not running, the Sonar.exe process is still running. In these cases, I need to completely reboot the system.
I get to our studio (just a personal project studio) about two weekends a month, so if you post some ideas and I do not reply it is just because I have not had a chance to try them yet.
Thanks in advance for the help.
Jim
Machine:
power: Enermax 430W
OS: XP Pro
Sonar 2.2 XL
Jim
