The Necromancer
Something about a death-mancer... ok... a lot of dead air at the beginning... haha get it? Dead air
(I'm an idiot
Reminds me of samicide's approach, w/out quite the skill level, or quality recording. Guitars do sound big... you're using a Pod, or something. J-Station, possibly. Well played... Everything's really "washy" in this mp3, so it's hard to tell if the muffly, muddy stuff is just mp3 noise...
Skillful arpeggios on the keys, there. Phantom of the opera.
Do you use a pop-filter on vocs? Quite a few plosives there. I'm thinking the guits swishyness stuff is mp3 noise... so I can't really comment on anything but generalities like... levels... which aren't bad... except when the vocs peak out around 2 db too loud for your mix.
Eq... mp3 noise... difficult to say.
Would like nice, clean gtrs with some good reverb on 'em... keys kind of spread across both spkrs (use a short delay), and vocs with some verb, but not as much as the gtrs (feed both into the same cathedral reverb, making the vocs dryer...)
That would be a suggestion to use with clean tracks... but I can't tell for sure if you tracked OK here, or not because of the mp3 noise.
Good work. W.I.S.C. might like this. Sam would probably give it a thumbs up.
As far as MOP...
Well played... the mp3 artifacts are very noticeable... like birds chirping on every note... but the gtr sounds good other than that. Some timing problems... but not bad. (subtractor... could be your player... Winamp3 makes some files sound really, really bad... and Winamp 2.78 sounds just fine on 'em).
Chad
